Error on updating fedora-36: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=fedora-36’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
stderr:
Error: Failed to download metadata for repo ‘updates’: Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/-metalink?repo=updates-released-f36&arch=x86_64 [Recv failure: Connection reset by peer]
unman
October 30, 2022, 2:39pm
#2
I get this error very often updating over Tor.
Sometimes updating in clear.
It’s a transitory network condition.
It seems to be affecting the non torrified connection also. Is there a network issue with the Qubes fedora repo?
I guess its a Fedora repo?
The fedora repo is resetting the connection…
I recently installed the cacher Salt recipe I wonder if that’s having an effect. The other error message that
is returned is Denied: qubes.UpdatesProxy
