Can someone confirm this, or vice versa, please? I just added f41 to Qubes, set it to update via cacher but for days absolutely unabel to upate . I am not kin to update via clear net. Thanks.
Error (the same for each Fedora repo, RPM and Qubes repos don’t complain:
rror loading local metadata for repository “fedora”
Librepo error: Checksum error /var/cache/libdnf5/fedora-xxxxxx/repodata/xxxxxx-primary.xml.zck: Unable to validate zchunk checksums
I’ve cleaned cacher, and restared apt-cacher-ng, both multiple times, dnf clean all-ed each time while trying, all to no avail.
Could be a cacher issue… I have no issues here with F41 template (without cacher) updates.
Great, thanks! Someone with cacher?
Could be a topic for unman, but he is very calm in the last couple of weeks. I remember we had a similar issue in previous Fedora versions too and I’m arguing those things probably will be gone with further updates of the F41 template.
This means for you: you probably can fix this issue only with manual downloads of the full template from qubes-templates-itl-testing store (and trying if the cacher will work with further 41s versions).
Or maybe someone else can help here…
Thanks. Actually I exactly started like that - from the scratch. Let’s see. It’'l be fixed at some point, I have no doubt.
Now when I think, I am lmost positive that I was actually never able to make the first update stock template succeeded via tor. I am pretty sure I can recall that when I first update template via clear net, I’m let to update it via tor afterwards, then. Why that would be, hmmm… Paranoia borealis…
