Fedora-32 template update icon stuck
Hi
I just added fedora-32 as my new template for Qubes. But the update icon is saying there is an update, even when I have clicked updates several times. The update icon just stays there and say there is an update for fedora-32.
This is the details from the Qubes update manager:
Updating fedora-32
fedora-32:
        ID: dnf list updates --refresh >/dev/null
  Function: cmd.run
    Result: True
   Comment: Command "dnf list updates --refresh >/dev/null" run
   Started: 22:08:44.720857
  Duration: 7123.154 ms
   Changes:
            pid:
                1093
            retcode:
                0
            stderr:
            stdout:
  Function: pkg.uptodate
    Result: True
   Comment: Upgrade ran successfully
   Started: 22:08:53.906003
  Duration: 23491.588 ms
   Changes:
  Function: cmd.run
    Result: True
   Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
   Started: 22:09:17.397797
  Duration: 3627.514 ms
   Changes:
            pid:
                1165
            retcode:
                0
            stderr:
            stdout:
  Summary for fedora-32
  Succeeded: 3 (changed=2)
  Failed:    0
  Total states run:     3
  Total run time:  34.242 s
Any help is appreciated.
Thanks in advance
try it in a template terminal, maybe it’s the pulseaudio known bug, see my post
Open fedora template terminal and type
$ sudo dnf upgrade --best --allowerasing
This is probably:
In which case it’s a known bug, and the fix is in current-testing.
qubes-vm-recommended-4.0.7-1.fc32.noarch
The above thing gets removed too. What is that?
