Hey guys, trying to get OpenVPN done but running into “faild to fetch” when doing so.
Have already run update and upgrade and running into same error
Any guidance?
Any guidance?
Just to make sure you’re updating properly, did you run the Qubes Update tool to update the packages then restart the app Qube? Also, for installing software, install the software in the template Qube, then shutdown the template and restart the app Qube. You can read these two pages from the documentation for more information:
