I tried updating the fedora vm. I did that, and changed from fedora 32 to 33 in the default option. Tried to update and i get this:
Updating fedora-33
Error on updating fedora-33: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=fedora-33’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
fedora-33:
_error:
Failed to return clean data
retcode:
1
stderr:
File “/var/tmp/.root_dd8a91_salt/salt-call”, line 27, in
salt_call()
File “/var/tmp/.root_dd8a91_salt/pyall/salt/scripts.py”, line 445, in salt_call
client.run()
File “/var/tmp/.root_dd8a91_salt/pyall/salt/cli/call.py”, line 48, in run
caller = salt.cli.caller.Caller.factory(self.config)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/cli/caller.py”, line 64, in factory
return ZeroMQCaller(opts, **kwargs)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/cli/caller.py”, line 329, in init
super(ZeroMQCaller, self).init(opts)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/cli/caller.py”, line 89, in init
self.minion = salt.minion.SMinion(opts)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/minion.py”, line 912, in init
opts[“grains”] = salt.loader.grains(opts)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/loader.py”, line 825, in grains
ret = funcskey
File “/var/tmp/.root_dd8a91_salt/pyall/salt/grains/core.py”, line 2384, in ip_fqdn
ret[“ipv6”] = salt.utils.network.ip_addrs6(include_loopback=True)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/utils/network.py”, line 1353, in ip_addrs6
return _ip_addrs(interface, include_loopback, interface_data, “inet6”)
File “/var/tmp/.root_dd8a91_salt/pyall/salt/utils/network.py”, line 1333, in _ip_addrs
ret.add(addr)
File “/usr/lib64/python3.9/ipaddress.py”, line 1925, in hash
return hash((self._ip, self._scope_id))
AttributeError: _scope_id
stdout:
What do i do? I have a vpn, but that’s not the issue is it?
How should i update when a new fedora is released? It would be easier if you used debian as the templateVM’s instead of fedora right? Less updates…
If i have installed a bunch of stuff in an templateVM and fedora version, do i need to install those again with every new fedora release? I’m not knowledgeable when it comes to this… Thanks in advance.
Thanks
