Hey, does anyone know why the sys-gui salt would return exit code 126 in the dummy-psu-sender and dummy-backlight-dom0 steps? Here are the logs:
local:
qvm.sys-gui.top:
status:
enabled
local:
qvm.sys-gui.top:
status:
enabled
[ERROR ] Command 'systemd-run' failed with return code: 126
[ERROR ] stdout: Running scope as unit: run-r4292bef18e8c46a39ac27b5eaf6a18b6.scope
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
Running '/usr/lib/qubes/qubes-download-dom0-updates.sh --doit --nogui '--exclude=qubes-template-*' '-y' '--best' '--allowerasing' '--clean' '--action=install' 'dummy-psu-sender'' on sys-firewall
sys-firewall: command failed with code: 126
[ERROR ] retcode: 126
[ERROR ] Error occurred installing package(s). Additional info follows:
errors:
- Running scope as unit: run-r4292bef18e8c46a39ac27b5eaf6a18b6.scope
[ERROR ] stdout: Running scope as unit: run-rcabf48a2a6a040e9860e5832858e7749.scope
Running '/usr/lib/qubes/qubes-download-dom0-updates.sh --doit --nogui '--exclude=qubes-template-*' '-y' '--best' '--allowerasing' '--action=install' 'dummy-backlight-dom0'' on sys-firewall
errors:
- Running scope as unit: run-rcabf48a2a6a040e9860e5832858e7749.scope
