@dom0 Thank you for the detailed info. Replacing the device name in the Device field with its MAC address seems to fix this issue. I have done several restarts and a few system updates without the connection breaking like before.
Regarding the disposable sys-net, this is very interesting. I will have to look into this more when I have more time.
Over the past week or so, my Qubes 4.1.0 installation has been relatively stable. However, just a few minutes ago, the OS froze/crashed on me (everything in the GUI is locked up, including mouse cursor).
I have seen a few reports of users stating that v4.1 works āflawlesslyā on their Librem 14, but I donāt see how that could be. I installed the OS from a verified ISO, using the Qubes instructions, and Iāve made ~0 configurations to the OS, yet the OS continues to freeze on me for no apparent reason. In this particular case, all I did was:
Boot up and sign in
Open terminal in a fedora-34 AppVM
Open terminal in a debian-11 AppVM
A few minutes later (I was reading something on my other PC), I noticed the OS froze on me. There were no updates being applied, I wasnāt running any other applications, and there is nothing plugged into the PC (not even the power adapter). I canāt imagine that I am the only one experiencing this, nor do I believe that this is the result of anything that Iāve done to the OS (which again is almost nothing).
Does anyone have any recommendations? Has anyone else experienced OS freezes? How concerned should I be about file system damage as a result of needing to force a shutdown when this happens?
For the storage, I have no experience but it should also work fine with all mainstream M2 SSD. Also, on the linked picture you can see that Pursim equips the Librem 14 with a Samsung storage but some reported issues with Trim on Samsung I cannot share any feedback on this but I can say crucial storage works fine for me too.
I finally updated to QubesOS R4.1 recently, and I noticed that the Screensaver is still enabled by default. I think that I read somewhere on this forum that the Screensaver can cause issues, similar to what I have read some users say about using suspend. It could be that the Screensaver is causing this OS freeze issue. I would recommend disabling it completely in the Settings Manager by selecting Mode: Disable Screen Saver. If you have already disabled it, then I am at a loss for what is causing the issue you are experiencing.
So here is a funny story: A few weeks ago, I was adding and editing my keyboard shortcuts to include shortcuts for different types of screenshots (fullscreen, window, region, etc.). I tested the shortcut that I selected for taking a screenshot of a region of the screen, but pressing the escape key did not stop the screenshot program from running. I could not click on anything, but the keyboard still worked. I did not know what to do in that moment to cancel the screenshot, so I manually powered off the computer. After booting back up, I ended up in the same situation and again manually powered off. It was not until a few weeks later that I realized that all I had to do was click and drag to select a region to screenshot, and then I could press escape to cancel it.
So that was my experience with what I thought was the OS freezing in some way, and I can say that manually powering down did not seem to cause any issues at all.
Youāre right⦠the 13 didnāt have an Ethernet port⦠and sharing the network thru sys-usb didnāt work out so well (for me at least). The 14 has and Ethernet port, and works well with Qubes.
I am running 4.1.0 with a Librem 14v1. I definitely have the problem with the WiFi not working when suspending and resuming, and it definitely worked on 4.0 with the same laptop. I am using a disposable sys-net qube (the default).
Upon resume, within sys-net, I see the following logs in dmesg:
ath9k ... Failed to initialize device
ath9k: probe of ... failed with error -12
I havenāt read the whole replies under your post, yet. But I just want to mention that the hang-up bug that you get (in which the Qubes OS just gets frozen and doesnāt continue with the booting-up the OS or shutting it down) occurs from time to time on my ThinkPad X220, too (using Qubes OS 4.1).
This is indeed a minor visual issue, however, I am concerned that there is a larger underlying issue that causes x11 work slow on dom0 especially when I have about 9 VM with multiple windows, twice already the laptop froze and I had to press power button to reboot. I am not connecting these issues yet, but searching for a fix to a small issue like graphics card, it may resolve the freezing issue.
I notice these small issues as someone who had 4.0.4 for a year and that was excellent. I might just downgrade from R4.1 to 4.0.4
I also wonder whether there is a performance issue related to Intel graphics. For example, when I work on a spreadsheet in LibreOffice, it is orders of magnitude slower than on my Windows machine, despite having 3 VCPUs, plenty of RAM (8 GB), and no other work to do. This may simply be because my Windows machine has a discrete graphics card, but then again, itās overall much less powerful and is 10 years old, so this dramatic difference in performance is a little confusing.
I have also had several system freezes. I get one about 4 times per week. It is very frustrating. I believe this has something to do with new updates becoming available and I say this because every time my system freezes, when I reboot, there is an update available. Whonix updates seem to cause the most trouble, but this is only anecdotal at this point. Note that I get my system updates through Whonix, because why not (although I may be regretting this because this seems to be a source of instability)?
For the past several weeks, Iāve also been experiencing qubes randomly and abruptly shutting down. Iāll just be sitting here working and Iāll see notifications like āQube sys-net has shut down.ā I have experienced this with sys-net, sys-firewall, sys-whonix, and some of the AppVMs. I believe this is also related to updates becoming available as mentioned above. Iāve noticed that, when updates become available, or I install them without rebooting the system, itās only a matter of time before qubes start randomly shutting down. Have you experienced this?
I used to have daily freezes as you describe (high load situations during backup or salt-based updates) with kernel 5.4 under Qubes OS R4.0 and had to stay on kernel 4.19. With Qubes OS R4.1 I am now on kernel 5.10 and have not seen any freezes yet. My laptop is a T430 with an i7-3840QM. I think itās very possible your situation might be similar (kernel version related).
Iāve never seen any random or abrupt shutdowns, except when I created them myself by misconfiguring qubes-shutdown-idle. Have you played with that?
