Hi. Please help me change the default plymouth theme. I want to replace the logo shown during password entry with this qubes sphere plymouth-themes/pack_1/cubes at master · adi1090x/plymouth-themes · GitHub.
However, I’m unable to get it working - when I replace the logo, the password input field disappears. This is what I’ve managed to do so far. I’d appreciate any assistance
# cycle through all images
for (i = 0; i < 81; i++)
logo.image[i] = Image("progress-" + i + ".png");
logo.sprite = Sprite();
# set image position
logo.sprite.SetX(Window.GetX() + (Window.GetWidth(0) / 2 - logo.image[0].GetWidth() / 2)); # Place images in the center
logo.sprite.SetY(Window.GetY() + (Window.GetHeight(0) / 2 - logo.image[0].GetHeight() / 2));
progress = 0;
fun refresh_callback ()
logo.sprite.SetImage(logo.image[Math.Int(progress / 2) % 81]);
progress++;
Plymouth.SetRefreshFunction (refresh_callback);
#----------------------------------------- Dialogue --------------------------------
status = "normal";
show_dots = 1;
show_plaintext_password = 0;
plaintext_password = "";
fun dialog_setup(text)
local.prompt;
local.entry;
local.aemsecret;
prompt.text = text;
prompt.image = Image.Text(text, 1, 1, 1);
# Try to load AEM secret image, if the file doesn't exists, plymouth shouldn't display anything
aemsecret.image = Image("antievilmaid_secret.png");
if (global.show_dots || global.show_plaintext_password) {
entry.image = Image("entry.png");
} else {
entry.image = Image.Text("Password bullets will be hidden", 0.8, 0.8, 0.8);
prompt.sprite = Sprite(prompt.image);
prompt.sprite.SetX(logo.sprite.GetX() + (logo.image.GetWidth() - prompt.image.GetWidth()) / 2);
prompt.sprite.SetY(logo.sprite.GetY() + logo.image.GetHeight() + 30);
prompt.sprite.SetZ(1);
prompt.sprite.text = text;
entry.sprite = Sprite(entry.image);
entry.sprite.SetX(prompt.sprite.GetX() + (prompt.image.GetWidth() - entry.image.GetWidth()) / 2);
entry.sprite.SetY(prompt.sprite.GetY() + prompt.image.GetHeight() + 30);
entry.sprite.SetZ(1);
help.image = Image.Text("|\n|\n|", 0.1, 0.1, 0.1);
help.sprite = Sprite(help.image);
aemsecret.sprite = Sprite(aemsecret.image);
aemsecret.sprite.SetX(entry.sprite.GetX() + (entry.image.GetWidth() - aemsecret.image.GetWidth()) / 2);
aemsecret.sprite.SetY(entry.sprite.GetY() + entry.image.GetHeight() + 30);
aemsecret.sprite.SetZ(1);
global.dialog.prompt = prompt;
global.dialog.entry = entry;
global.dialog.help = help;
global.dialog.aemsecret = aemsecret;
global.dialog.bullet_image = Image("bullet.png");
dialog_opacity(1);
fun dialog_opacity(opacity)
dialog.prompt.sprite.SetOpacity(opacity);
dialog.aemsecret.sprite.SetOpacity(opacity);
dialog.entry.sprite.SetOpacity(opacity);
dialog.help.sprite.SetOpacity(opacity);
if (global.show_dots) {
for (index = 0; dialog.bullet[index]; index++) {
dialog.bullet[index].sprite.SetOpacity(opacity);
if (global.show_plaintext_password) {
dialog.plaintext_password.sprite.SetOpacity(opacity);
fun display_normal_callback()
global.status = "normal";
if (global.dialog)
dialog_opacity(0);
fun display_prompt_callback(prompt, password, is_secret)
bullets = password.Length();
global.plaintext_password = password;
if (prompt.SubString(0,32) == "Please enter passphrase for disk") {
prompt = "Disk password";
global.status = "password";
if (!global.dialog) {
dialog_setup(prompt);
} else {
if (global.dialog.prompt.text != prompt) {
dialog_opacity(0);
global.dialog = NULL;
} else {
dialog_opacity(1);
max_password_width = dialog.entry.image.GetWidth()-5*2;
dialog.plaintext_password.image = Image.Text(password);
password_width = dialog.plaintext_password.image.GetWidth();
if (password_width > max_password_width)
dialog.plaintext_password.image = dialog.plaintext_password.image.Crop(password_width-max_password_width, 0, max_password_width, dialog.plaintext_password.image.GetHeight());
dialog.plaintext_password.sprite = Sprite(dialog.plaintext_password.image);
dialog.plaintext_password.sprite.SetX(dialog.entry.sprite.GetX() + 5);
dialog.plaintext_password.sprite.SetY(dialog.entry.sprite.GetY() + dialog.entry.image.GetHeight() / 2 - dialog.plaintext_password.image.GetHeight() / 2);
dialog.plaintext_password.sprite.SetZ(2);
dialog.plaintext_password.sprite.SetOpacity(1);
} else {
dialog.plaintext_password.sprite.SetOpacity(0);
for (index = 0; dialog.bullet[index] || index < bullets; index++) {
if (!dialog.bullet[index]) {
dialog.bullet[index].sprite = Sprite(dialog.bullet_image);
dialog.bullet[index].sprite.SetZ(dialog.entry.sprite.GetZ() + 1);
/* Always update position, otherwise bullets added during no echo mode will be at the wrong position */
dialog.bullet[index].sprite.SetX(dialog.entry.sprite.GetX() + 5 + (index % 21) * (dialog.bullet_image.GetWidth() + 2));
dialog.bullet[index].sprite.SetY(dialog.entry.sprite.GetY() + dialog.entry.image.GetHeight() / 2 - dialog.bullet_image.GetHeight() / 2);
if (index < bullets && global.show_dots)
dialog.bullet[index].sprite.SetOpacity(1);
else
dialog.bullet[index].sprite.SetOpacity(0);
fun keyboard_input_callback(key){
if (key == "e[[A") {
global.show_dots = 0;
global.show_plaintext_password = 0;
dialog_setup(global.dialog.prompt.text);
display_prompt_callback(global.dialog.prompt.text, global.plaintext_password, 1);
} else if (key == "e[[B") {
global.show_dots = 1;
} else if (key == "e[19~") {
global.show_plaintext_password = 1;
Plymouth.SetKeyboardInputFunction(keyboard_input_callback);
Plymouth.SetDisplayNormalFunction(display_normal_callback);
Plymouth.SetDisplayPromptFunction(display_prompt_callback);
#----------------------------------------- Progress Bar --------------------------------
progress_box.image = Image("progress_box.png");
progress_box.sprite = Sprite(progress_box.image);
progress_box.sprite.SetX((Window.GetWidth() - progress_box.image.GetWidth()) / 2);
progress_box.sprite.SetY(Window.GetHeight() - 50 - progress_box.image.GetHeight() / 2);
progress_bar.original_image = Image("progress_bar.png");
progress_bar.sprite = Sprite();
progress_bar.sprite.SetX(progress_box.sprite.GetX() + (progress_box.image.GetWidth() - progress_bar.original_image.GetWidth()) / 2);
progress_bar.sprite.SetY(progress_box.sprite.GetY() + (progress_box.image.GetHeight() - progress_bar.original_image.GetHeight()) / 2);
fun progress_callback(duration, progress)
if (progress_bar.image.GetWidth() != Math.Int (progress_bar.original_image.GetWidth() * progress)) {
progress_bar.image = progress_bar.original_image.Scale(progress_bar.original_image.GetWidth() * progress, progress_bar.original_image.GetHeight());
progress_bar.sprite.SetImage(progress_bar.image);
Plymouth.SetBootProgressFunction(progress_callback);
#----------------------------------------- Quit --------------------------------
fun quit_callback()
logo.sprite.SetOpacity(1);
Plymouth.SetQuitFunction(quit_callback);
#----------------------------------------- Message --------------------------------
message_sprites = [];
message_sprite_count = 0;
message_sprite_y = 10;
fun display_message_callback(text)
my_image = Image.Text(text, 1, 1, 1);
message_sprites[message_sprite_count] = Sprite(my_image);
message_sprites[message_sprite_count].SetPosition(10, message_sprite_y, 10000);
message_sprites[message_sprite_count].text = text;
message_sprite_count++;
message_sprite_y += my_image.GetHeight();
fun hide_message_callback (text)
for (i = 0; i < message_sprite_count; i++) {
if (message_sprites[i].text == text)
message_sprites[i] = NULL;
Plymouth.SetDisplayMessageFunction(display_message_callback);
Plymouth.SetHideMessageFunction(hide_message_callback);
# vim: ts=4 sw=4 et
