3isec-tor is great. It would be nice to have examples for 3isec-tor downstream vms. I am particularly interested in below two topics.
How to install tor browser in a downstream vm and use the tor service in sys-tor.
How to route connections through socks ports defined in 3isec-tor. Let’s say I am running wget, curl, apt-cacher-ng in downstream vm. How to route connections through socks port 9050 in sys-tor?
Does setting CookieAuthentication 1 means downstream vms should have access to the cookie file in sys-tor?
You can run tor browser without using Tor - this is, I think, what
Whonix does. Configure it to use upstream proxy on first start.
You can no longer run Tor over Tor.
Or use Mullvad Browser, developed with the Tor project.
By default, any TCP traffic is routed to the TransPort on 9040 -
configured “IsolateClientAddress”.
If you want to use the Socks Port on 9050 - “IsolateClientAddress
IsolateSocksAuth”, just follow usual guidance on using an upstream
proxy:
You can put the export lines in ~/.bashrc in the qube.
That option is used to authenticate controllers to the tor instance, so
that only authorized controllers can connect. In this case the
ControlPort is bound to the local interface, so not accessible from
downstream qubes.
I don’t think we can browser onion address using mullvad browser. I tried and it does not work as is. Probably needs more tweaking.
I don’t think we can use http(s)_proxy to use socks port. I think we need to use applications like torsocks or socat from tcp to socks in order to forward connections to socks port. I am not sure so that’s why I posted the question to see if anyone has done the setup already.
I checked whonix repository and its not easy to understand. I think there might be a much simpler solution than what is done for whonix.
I noticed statements in whonix wiki about transferring cookie auth file from gateway vm to workstation vm. I am not sure under what circumstances the cookie auth file is required in workstation vm. Hence posted the question to the community.
