Hi there, i had prior help installing browsers repos to Fedora Templates but unfortunately however hard i try i just cant get the same to happen on the Debian Templates.
I have Debian-12 and Debian-12-xfce and i have tried so so much and failed every step of the way.
Debian-12 Template i tried downloading things from the Software Package but it says i need internet to do it which was not the case with Fedora Template.
Debian-12-xfce i dont even have Software Package.
I would love to have brave browser and LibreWolf Browser ideally.
I also tried following this guide but it not work for me.
I do also have kali-Core and Whonix Templates and i cant download anything what-so-ever to them, maybe they are way to complicated for me or something idk
I did try and re-read the other posted question about the similar topic yet for Fedora and i followed everything and even tried doing the Flatpak option but nothing at all worked for me.
Any help is much appreciated please. Thanks
lol, i dont use it as im not clever enough, i was trying to find different distros to have other than Deb and Fedora and that was all that was there in the Qubes GUI Qubes Template Manager so i thought why not give it a go but now after hearing you i have deleted that Template straight away.
I tried to C&P the commands in from the URl but no work for me and i not understand anything about a proxy or how or when or where to insert it
I had to be root to input the command you gave me so i just in-putted sudo before the command and a space, i hope that was correct to do.
So i put in your proxy command into template terminal then on that url do i start C&Pasting the commands and do i start with the 1st being; curl-proxy and then; wget-proxy and so on or should i exclude the top 2 proxy things because i already in-putted your given proxy do you know?
I have read your post a few times and i not understand any of it, i feel so so stupid like i cant speak basic words yet i really really do want to understand all of this stuff but just grasp basic stuff
I am so stupid i even C&Pasted your command example in CLI thinking that might of been a command…lol
Don’t worry, first of all, English in not my first language and there are a lot of other reasons why you may not understand my post.
I was trying to tell you that is that, when you say:
It’s very hard to know which exact command were typed, where and why they don’t work. It’s better to write something like this:
I tried to run this command in the template debian-12-xfce:
apt update
But it doesn’t work:
Reading package lists... Done
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
The curl-proxy and wget-proxy are supposed to be bash scripts. It seems to me that it’s way too difficult given your current level of knowledge (I said “current” ! ). Maybe try the last command @apparatus gave you instead?
Just follow the official guides to install the browsers but replace strings: curl with curl --proxy http://127.0.0.1:8082/ wget with https_proxy=http://127.0.0.1:8082/ http_proxy=http://127.0.0.1:8082/ wget extrepo with https_proxy=http://127.0.0.1:8082/ http_proxy=http://127.0.0.1:8082/ extrepo
