i am on qubes 4.2.4 been using for months now when upgrading dom0 i am getting the following errors and upgrade doesnt work
Checking for available updates for dom0…
Using sys-firewall as UpdateVM for Dom0
Checking for dom0 updates…
Updating and loading repositories:
Qubes Host Repository (updates) ???% | 0.0 B/s | 0.0 B | 00m15s
Curl error (60): SSL peer certificate or SSH remote key was not OK for https
Cannot prepare internal mirrorlist: Curl error (60): SSL peer certificate or
Fedora 37 - x86_64 - Updates 100% | 220.6 KiB/s | 11.8 MiB | 00m55s
Fedora 37 - x86_64 100% | 436.4 KiB/s | 34.2 MiB | 01m20s
Failed to download metadata (metalink: “https://yum.qubes-os.org/r$releasever/current/host/fc37/repodata/repomd.xml.metalink”) for repository “qubes-dom0-current”: Cannot prepare internal mirrorlist: Curl error (60): SSL peer certificate or SSH remote key was not OK for https://yum.qubes-os.org/r$releasever/current/host/fc37/repodata/repomd.xml.metalink [SSL certificate problem: certificate is not yet valid]
Failed to check for dom0 updates
