/usr/lib/python3/dist-packages/dnf/const.py:22: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
import distutils.sysconfig
/usr/lib/python3/dist-packages/dnf/const.py:22: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
Unable to detect release version (use '--releasever' to specify release version)
~3isec Qubes Dom0 Rep [ === ] --- B/s | 0 B --:3isec Qubes Dom0 Repository (updates) 16 B/s | 262 B 00:16
Errors during downloading metadata for repository '3isec-dom0-current':
- Status code: 404 for https://qubes.3isec.org/rpm/r$releasever/current/dom0/fc32/repodata/repomd.xml (IP: 195.10.223.181)
Error: Failed to download metadata for repo '**3isec-dom0-current**': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Fetching updates failed with code 1; press Enter to exit
Well the warnings are just that.
The error comes because (as you are told) “Unable to detect release
version (use ‘–releasever’ to specify release version)”
Because you cannot detect releasever, the URL you use in bogus -
rpm/r$releasever/ instead of rpm/r4.1
I don’t understand, sorry. Release version was never, ever detected, and it worked until a week or so ago, and now I’m not sure what is your suggestion.
Well, something has changed recently, obviously.
While Fedora repos work without it, Qubes repos will not work anymore without --releasever=4.1 switch, including your repo.
cacher on bookworm. But it worked until a week ago. But, I tried sys-whonix, while converting back to http(s) from http://HTTPS///, and still the same. Will not try via clearnet.
Still the same issue. All other qubes can be updated without recognizing releasever, except dom0, which makes it impossible to update it automatically, nor via salt, as far as I know.
Putting --releasever=4.1 at the end of qubes-dom0-update command works, namely things like this one works
[user@dom0 ~]$ sudo qubes-dom0-update --enablerepo=qubes-dom0-current-testing --action=upgrade --releasever=4.1
Using cacher as UpdateVM to download updates for Dom0; this may take some time...
No updates available
but this doesn’t work
Error
[ERROR ] Command failed with status 1. Additional info follows:
cmd:
- --quiet
- --console
- --show-output
- --action=list
- upgrades
retcode:
1
stderr:
Running scope as unit: run-rxxxxxxx.scope
Using cacher as UpdateVM to download updates for Dom0; this may take some time…
Unable to detect release version (use ‘–releasever’ to specify release version)
Error: Failed to download metadata for repo ‘3isec-dom0-current’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
stdout:
local:
Function: file.replace
Result: True
Comment: No changes needed to be made
Started: 07:24:03.435928
Duration: 27.556 ms
Changes:
Result: True
Started: 07:24:03.463751
Duration: 7.716 ms
Changes:
Function: cmd.run
Name: if qubes-dom0-update --quiet --assumeyes --clean --action=clean expire-cache >/dev/null 2>&1; then
echo "result=True comment='Cache cleaned'"
else
echo “result=False comment=‘Could not clean cache’”
fi
Function: pkg.uptodate
Result: False
Comment: Command failed with status 1. Additional info follows:
cmd:
- --quiet
- --console
- --show-output
- --action=list
- upgrades
retcode:
1
stderr:
Running scope as unit: run-r178bbe16678244a0a0213aa42598edfc.scope
Error: Failed to download metadata for repo '3isec-dom0-current': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
stdout:
Started: 07:24:16.111560
Duration: 14949.636 ms
Changes:
Summary for local
Succeeded: 3
Failed: 1
Total states run: 4
Total run time: 24.234 s
DOM0 configuration failed, not continuing
Is there a way to put somewhere --releasever so salt could work?
You are trying to update dom0 on a testing unreleased platform.
Just don’t do this.
I’ve told you before - bookworm is testing - things will break. Don’t
use it for security critical things - like dom0.
If you tell me that this happens on bullseye, I’d be concerned. (It
doesn’t - at least,not for me.)
Whonix? I don’t know. It’s a question for the Whonix folk.
