ng0177
July 16, 2022, 5:33pm
1
qvm-run --pass-io <src-vm> 'cat /path/to/file_in_src_domain' > /path/to/file_name_in_dom0
creates on the first of two bare-metal Qubes OS installations only an empty file with no content is generated whereas in the second, no problems are found for the identical command.
I also noticed on the first problematic installation a file called “Qubes-HCL…yaml” which the system seems to have created containing some FIXME tags.
Could you be more specific?
ng0177:
Which second?
In which full path?
ng0177
July 16, 2022, 7:26pm
3
first: bare metal desktop
second: bare metal desktop w/ almost identical hardware
works well, my mistake to forget the cube name but -v did not complain either. EDIT -v now included.
[user@personal qvm-screenshot]$ cat /home/user/QubesIncoming/dom0/Qubes-HCL-Micro_Star_International_Co___Ltd_-Cubi_N_JSL__MS_B0A1_-20220715-200349.yml
layout:
'hcl'
type:
'desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Micro-Star International Co., Ltd.
model: |
Cubi N JSL (MS-B0A1)
bios: |
8.20
cpu: |
Intel(R) Pentium(R) Silver N6000 @ 1.10GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:4e26]
chipset-short: |
FIXME
gpu: |
Intel Corporation JasperLake [UHD Graphics] [8086:4e71] (rev 01) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Wi-Fi 6 AX201 160MHz (rev 01)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
memory: |
16139
scsi: |
usb: |
1
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.48-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
I guess, I prefer to delete all that from here whence you have seen it.
(I’ve made the title more specific)
Can you reproduce that behaviour?
Move /home/user/QubesIncoming/dom0/Qubes-HCL-Micro_Star_International_Co___Ltd_-Cubi_N_JSL__MS_B0A1_-20220715-200349.yml to a backup location. Then run qvm-run again. Watch out for typos. Give us the command line in full (copy&paste).
Most likely a typo in the name of the sourceVM.
Don’t worry, I only have one eye.
ng0177
July 17, 2022, 6:04pm
6
No, I paid attention: the problem is not reproducible.
My only advice would be to empower -v to give the user an error message when that happens.
This usually happens if one misspells the name of <src-vm>. Check your ~/.bash_history in dom0.
Grep for qvm-move(-to-vm) or qvm-copy(-to-vm) in your ~/.bash_history in dom0.
