Does enabling crond service, works as expect in AppVM
Just want to launch a daily backup script *.sh using crond (or other method).
Will it work if the AppVM (debian template) is running with crond service enabled by:
qvm-service -e crond [or enabled through the GUI]
There is no simple and clear examples for such a simple task.
crontab -l is:
m h dom mon dow command
0 1 * * * /home/user/000run_daily/duplicity_backup.sh > /dev/null 2>&1
0 2 * * * /home/user/000run_daily/mirror_lftp.sh > /dev/null 2>&1
It does not work for me
What extra steps is needed to configure crond in QubesOS?
Just start crond from rc.local and also copy the crontab at the right place.
Otherwise you could write a systems timer to trigger the backup.
In the file in the App VM at: /rw/config/rc.local
I should add 2 lines:
systemctl enable cron.service
systemctl start cron.service
then restart the AppVM
What is copy crontab in the right place?
currently the jobs seem to be at:
/var/spool/cron/crontabs/user
and
/rw/bind-dirs/var/spool/cron/crontabs/user
where should I copy this file to?
No need to copy, crontab -e put stuff in the right places
It is working now
Thanks for the help
