I’ve tried to move Docker data to AppVMs both by bind-mounts and by {"data-root": "/rw/docker-data"} in /etc/docker/daemon.json. In both cases, it stops working after reboot:
% docker run -it debian bash
bash: error while loading shared libraries: /lib/x86_64-linux-gnu/libc.so.6: cannot apply additional memory protection after relocation: Permission denied
According to my investigations, it looks like being caused by SELinux. I’ve fixed it multiple times, but I don’t know the exact steps (might add it later). It was related to changing SELinux contexts.
Further investigations (and one accident with timeout due to qubes-relabel-rw.service) have pointed to /rw/.autorelabel. It looks like due to presence of .autorelabel, the whole /rw is getting changed SELinux labels on every boot. Can I safely remove it? What’s the purpose of /rw/.autorelabel?
Alternatively, you can try using a Debian-based template
the /rw/.autorelabel is needed to fix the SELinux lables after you modify files in /rw, which are then used in other places (for example, under /rw/config/NM-system-connections which is linked under /etc/NetworkManager) - which otherwise will fail.
It looks like /rw/.autorelabel is automatically created. So, after every boot, I need to run the two commands above. Not nice, but at least some workaround.
Removing /rw/.autorelabel file will actually trigger relabeling on next boot (yeah, it behaves differently than /.autorelabel).
But also, the actual issue is because Fedora’s SELinux policy applies container labels to /var/lib/docker, not the alternative directory. But, if you keep the original directory in the configuration, but move it to /rw using bind-dirs, it will work. See How to make any file persistent (bind-dirs) — Qubes OS Documentation
Hmm, with bind-dirs, it works, thank you! (Tested with clean template.) I remember having issues even with bind-dirs (I used bind-dirs before data-root), but maybe this is a past issue that has been fixed.
So, maybe it’s time to use /etc/qubes-bind-dirs.d, as this can configure it in TemplateVM.
IIUC, the /rw is also getting relabeled when context file is changed. So, I will still get this issue after some updates.
However, I am unable to reproduce this in my testing AppVM (TemplateVM: fedora-42 testing + updates + docker, otherwise vanilla), even removing /rw/.autorelabel doesn’t reproduce it. In my production AppVM (TemplateVM: fedora-42 with many packages and some adjustments), it still occurs. Not sure what’s the important difference.
