Yeah, I know that. Hence I wrote “Not sure, how this could be beneficial for consistency”. Whether it is a good idea to have sys-net
as upstream to enforce firewall rules is a different topic. It wouldn’t help with OP issue of firewall rules not been consistently applied.
Well, it might. We don’t know and can’t reproduce how your system got into the state it did, but having a firewall qube that just does one thing removes some potential causes.
Just about configuring them, to be clear - nft should be solid once the rules are set up. Maybe systemd should be watching qubes-firewall
If I can reproduce this in any way, I surely will create a GitHub issue, so core developers can judge, if this is something to be fixed or works as intended.
All right, thanks to both of you!
Should be easy to confirm: kill the qubes-firewall
process on the target netvm, try adding a new rule with qvm-firewall
on dom0, verify the rule isn’t present with nft list ruleset
on the netvm.
