Dnf install failure...basically can't find right mirror
Fairly new Fedora qubes install. Anytime I run sudo dnf install -y it fails staing
Error: Failed to download metadata for repo ‘updates’: Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=updates-released-f40&arch=x86_64 [CONNECT tunnel failed, response 500]
What are your Update Proxies set to in Qubes Global Config under the “Updates” tab?
Do you have any VPN kill-switch enabled?
Are you getting the same error when you run Qubes Updater?
