So I create a DispVM from whonix-ws-15-dvm named whonix-ws-15-dvm1. But when I’m trying to use torbrowser I have the following error :
ERROR: Do not run Tor Browser in Qubes DVM Template!
More info: https://www.whonix.org/wiki/Tor_Browser/Advanced_Users#Running_Tor_Browser_in_Qubes_TemplateVM_or_DVM_Template
The solution is to remove in the name of the dispvm “whonix-ws-15-dvm1” the “dvm”
Now with the new name of the dispvm with “whonix-ws-15-1” there is no error when starting torbrowser
The error message you received indicates that your whonix-ws-15-dvm1 is
a template (maybe cloned from whonix-ws-15). Please read the
documentation linked and ask for more help if needed.
How are you launching the DispVM? The way I described in my post?
If the windows says [whonix-ws-15-my-] then you haven’t launched a
disposable qube but the respective template. If you launch through the
menu or using the command line I posted the qube name should show as
[dispXXXX] where XXXX is a semi-random number.
