Disposable Samba server VM for LAN only?
I’d like to share media from an external hard drive with devices on my local network using SMB through a Qubes VM. As I use external storage, the VM can be disposable. The VM should only be able to serve via SMB and only to the local network, no other connections. It should only need to be configured once - I’m not sure how much of this could live in the template.
Is this possible? I’ve seen a lot about accessing local storage serves from Qubes, but not the other way around.
