I have a very stable Qubes 4.0 that I’ve been using for years on a Lenovo Thinkpad P51.
The machines has hybrid Intel + NVidia graphics.
I had absolutely no issues in 4.0 - except that I couldn’t mount anymore EXFAT filesystems after I upgraded my Fedora VMs to Fedora 34, as it seems that Qubes 4.0 was not able to provide the correct recent kernel with EXFAT support.
So I upgraded to 4.1 RC4 - The upgrade went well.
After upgrading the good news is that I get the EXFAT support in my VMs.
Bad news is that I get a whole lot of graphics corruption and instability. (using Fedora VMs)
First I notice small visual corruption in the Plymouth splash screen during boot.
Symptoms are that with some applications, resizing windows will completely fail to resize the windows contents, making such applications unusable.
Trying to process the same contents with different apps works perfectly for reasons I don’t understand.
i.e. : Opening documents with LibeOffice shows graphics issues, opening them with OnlyOffice Desktop Editors is OK.
Opening password files with keepass shows graphics issues, opening them with keepassxc is OK.
Opening RDP sessions with Remmina shows graphics issues, opening them with xfreerdp is OK.
If trying to play several times with a window that is failing, this usually ends in the applications crashing (window disappears) but I’ve seen 4 times THE WHOLE SYSTEM SUDDENLY REBOOT.
(The hardware had been perfectly stable with Qubes 4.0).
I tried using only the NVidia graphics card by disabling the “hybrid“ feature in BIOS, and I noticed the graphics were more reactive, and no corruption in Plymouth during boot.
But with NVidia only, the problematic app stays problematic and behave differently :
When enlarging windows, the windows will redraw properly up to a given size, if enlarged further they will stop redrawing, and it continuing to fiddle with them the whole system will eventually crash.
Any clue to solve this would be greatly appreciated as having this system usable is paramount for me ; if I can’t find a solution very quickly, I will have to downgrade my system to the previous, stable, Qubes 4.0.
Thanks for having read.
