Disk storage max Size issues
So I am trying to sync the monero blockchain to a node.
I set private storage max size to 13448 MiB,(120gb) more than enough.
However, when I run df -h in the terminal I get:
Size Used. Avail.
Dev/xvdb 13GB. 13GB. 0
Why does this block have a limit when I set the max limit to 120GB.
(My system storage max size is 10240MiB.)
My qube is on the dynamically change size if that even matters.
You are a factor of 10 out on your calculation.
13448MB is about 13.1GB
