Trying to set up apt-cacher-ng, followed the instructions at both https://github.com/unman/notes/blob/master/apt-cacher-ng and https://github.com/behemothwerecat/deb-min/blob/main/instructions.md.
However, attempting to use apt in any template fails:
sudo apt update Err:1 http://HTTPS///deb.debian.org/debian bullseye InRelease Connection failed [IP: 127.0.0.1 8082] ... W: Failed to fetch http://HTTPS///deb.debian.org/debian/dists/bullseye/InRelease Connection failed [IP: 127.0.0.1 8082]
I’m using R4.1, I can’t think of any reason that would be a problem. Does anyone have any advice for this?
Let’s start with the basics…
- is apt-cacher-ng running? (sudo systemctl status apt-cacher-ng)
- is the correct qube set in your qubes.UpdatesProxy?
Yup, it’s running. (in the appvm named “cache-test”)
My testing 30-user.policy file in /etc/qubes/policy.d/ reads:
# Upgrade Whonix TemplateVMs through sys-whonix.
qubes.UpdatesProxy * @tag:whonix-updatevm @default allow target=sys-whonix
# Deny Whonix TemplateVMs using UpdatesProxy of any other VM.
qubes.UpdatesProxy * @tag:whonix-updatevm @anyvm deny
# Default rule for all TemplateVMs
qubes.UpdatesProxy * @type:TemplateVM @default allow target=cache-test
qubes.UpdatesProxy * @anyvm @anyvm deny
Forgive me for asking, but just to make sure: cache-test is connected to a netvm?
Have you added the iptable rule in cache-test to allow port 8082?
Have you edited the port number in acng.conf to be 8082?
Yes, connected to sys-net.
Current iptables:
user@cache-test:~$ sudo iptables -S
-P INPUT DROP
-P FORWARD DROP
-P OUTPUT ACCEPT
-N QBS-FORWARD
-A INPUT -p tcp -m tcp --dport 8082 -j ACCEPT
-A INPUT -m state --state INVALID -j DROP
-A INPUT -i vif+ -p udp -m udp --dport 68 -j DROP
-A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i vif+ -p icmp -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -i vif+ -j REJECT --reject-with icmp-host-prohibited
-A INPUT -j DROP
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -j QBS-FORWARD
-A FORWARD -i vif+ -o vif+ -j DROP
-A FORWARD -i vif+ -j ACCEPT
-A FORWARD -j DROP
Yes, port is set.
What happens if you do telnet 127.0.0.1 8082 in the template? Do you get Connected to 127.0.0.1?
Yes, and then immediately after, the templates started being able to connect. confusing…
