Denied: qubes.UpdatesProxy
Yes, the issue that this topic is all about.
I just get a popup about it not working.
I haven’t been able to fix it yet. As I don’t know what is wrong.
The Debian Guests need to target the correct location for whatever country you are in.
Needs to have the template updated to http://ftp.{COUNTRYCODE}.debian.org/ instead of https://deb.debian.org
I don’t know why they changed it.
Various users reported an error but with different root causes, as far
as I can see.
What does the popup say?
It’s likely that you need to look at the policy file under
/etc/qubes/policy, or use the GUI.
You can do this if you choose, as you can make any change that you will.
Read this
Thanks, this solved it for me! In my case the file was missing for some reason… worked fine before I fiddled around with moving the VMs to another nvme…
Same problem here with v4.3.0.
denied: qubes.updatesproxy for gateway & workstation
I have not changed anything in Qubes, system is still all default install.
