I guess I am asking. If I install Qubes 4.1-RC2 and let it update, would it be the same for the latest Qubes 4.1 ISO by date?
Or does [Qubes-20211120-x86_64.iso] have experimental features?
I am mainly experimenting, so promise of high level security not relevant.
alzer89
2
Pretty much. In fact there are some machine that seem to only let you install the latest version of Qubes OS that way…
I wish…
You will most likely end up with more recent packages from the Fedora repos…
They’d both end up the same after sudo qubes-dom0-update
