Dell XPS 9520
layout:
  'hcl'
type:
  'notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  XPS 15 9520
bios: |
  1.18.0
cpu: |
  12th Gen Intel(R) Core(TM) i7-12700H
cpu-short: |
  FIXME
chipset: |
  00.0 Host bridge [0600]: Intel Corporation Device [8086:4641] (rev 02)
chipset-short: |
  FIXME
gpu: |
  02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  14.3 Network controller: Intel Corporation Device 51f0 (rev 01)
memory: |
  65207
scsi: |
usb: |
  3
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.6
  kernel: |
    6.4.8-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
Working:
  • video
  • audio
  • camera
  • wifi
  • dell dock
Not working:
  • qvm-pci (VM devices tab greyed out)
  • Suspend (can suspend, won’t wake)
Not tested:
  • bluetooth
  • sd card reader
A fix has been merged for 4.2. Currently in testing repo (shouldn’t be long to reach the stable repo).
Don’t know if it will be applied to 4.1 (for now, it’s not in 4.1 current-testing)
Related github issue:
Listing PCI devices breaks when there is some with non-0000 PCI domain #6932
Related forum post:
https://forum.qubes-os.org/t/major-problem-with-qvm-pci-and-devices-in-general/8359/16
From the pull request:
Ignore PCI devices on non-0000 domain instead of crashing #560
This is a quick band-aid to unbreak Qubes on systems having such device.
Later change should implement handling them properly instead of ignoring.
As you have 4.1 and the fix is not in this version (don’t know if it will, probably yes), either apply the fix from the forum post (link above) or directly from the commit:
https://github.com/QubesOS/qubes-core-admin/pull/560/commits
the file in dom0 is there:
/usr/lib/python3.11/site-packages/qubes/ext/pci.py
Thank you @yerill for your HCL report, which is online now!
@yerill , Can you please say something regarding discrete GPU: do you use it/does it work at all? any issues with it? does it work all the time or is there any mechanism in place to handle the load between internal and discrete GPUs?
Thanks. Since I have a workaround using a usb-c nic, I think I’ll wait for 4.2.
I’ve not tried to use the discrete GPU.
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  XPS 15 9520
bios: |
  1.23.0
cpu: |
cpu-short: |
  FIXME
chipset: |
  00.0 Host bridge [0600]: Intel Corporation 12th Gen Core Processor Host Bridge/DRAM Registers [8086:4641] (rev 02)
chipset-short: |
  FIXME
gpu: |
  02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P GT2 [Iris Xe Graphics] [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  14.3 Network controller [0280]: Intel Corporation Alder Lake-P PCH CNVi WiFi [8086:51f0] (rev 01)
memory: |
  65207
scsi: |
usb: |
  3
certified:
  'no'
versions:
  - works:
    qubes: |
      R4.2.1
    xen: |
      4.17.4
    kernel: |
      6.9.4-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Working:
  • video
  • audio
  • camera
  • wifi
  • dell dock
  • sleep
Sleep required the kernel-latest, and changes here: Support for the S0ix sleep state · Issue #6411 · QubesOS/qubes-issues · GitHub
Not tested:
  • discrete GPU
  • bluetooth
  • sd card reader
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  XPS 15 9520
bios: |
  1.22.0
cpu: |
cpu-short: |
  FIXME
chipset: |
chipset-short: |
  FIXME
gpu: |
gpu-short: |
  FIXME
network: |
memory: |
  16055
scsi: |
usb: |
  3
certified:
  'no'
versions:
  - works:
    qubes: |
      R4.2.3
    xen: |
      4.17.5
    kernel: |
      6.6.54-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Please accept an HCL report from me as well.
Please advise what should I test more …
I initially thought sleep was working correctly, but it was only suspending and resuming while still consuming too much battery and if enclosed in a backpack getting warm.
I’ve posted more here: Dell XPS 9520 Issues
