layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Dell Inc.
model: |
Precision 7740
bios: |
1.24.0
cpu: |
Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:3e20] (rev 0d)
chipset-short: |
FIXME
gpu: |
Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] [8086:3e9b] (rev 02) (prog-if 00 [VGA controller])
NVIDIA Corporation TU106GLM [Quadro RTX 3000 Mobile / Max-Q] [10de:1f36] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
Intel Corporation Wi-Fi 6 AX200 (rev 1a)
memory: |
130811
scsi: |
usb: |
4
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
6.1.42-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
4K display has known issue that is unrelated to Qubes but is worth mentioning. Sleep/hibernation will cause display issues that may trigger epileptic seizures, solution is to disable that functionality and preferably use external monitors for UX reasons. However, problem persists through reboots, and requires some time powered off to cease. For that reason, I specifically use external monitors.
In 4.1.2 stable ethernet card had the PCI reset issue, solution is in No network after install - #8 by Sven
So far that is all I’ve run into, but if there are more things I can test help fill in gaps let me know.
Currently using thunderbolt 3 dock with displays, only complaint there is trying to disable the laptop display causes so much lag that I can’t save the settings in time so the settings revert.
