layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Dell Inc.
model: |
Precision 7560
bios: |
1.5.0
cpu: |
11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a36] (rev 05)
chipset-short: |
FIXME
gpu: |
Intel Corporation TigerLake-H GT1 [UHD Graphics] [8086:9a60] (rev 01) (prog-if 00 [VGA controller])
NVIDIA Corporation Device [10de:1fbc] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Ethernet Connection (14) I219-LM (rev 11)
Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
memory: |
15573
scsi: |
usb: |
3
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.89-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Took a little while but got Qubes 4.1 running on Dell Precision 7560 (also known as ‘la grosse bertha’).
For the OS to be able to boot :
- Need to change in BIOS to AHCI (F12 → BIOS → Storage → Disable RAID and switch to AHCI ) as in ([qubes-users] Dell Precision 5750)
Install the OS. I used debian 11 as default
In order to get sys-net working :
After the first boot, go to sys-net settings (VM must be powered off) and configure strict reset for PCI for the ethernet controller. (sys-net settings → Devices → Configure strict reset for PCI devices → chose ethernel controller)
Shutdown the VM
In order to get the wifi working :
The kernel version was causing problem with the AX210 wifi controller of the laptop
Start debian 11 template.
sudo mv /lib/firmware/iwl-wifi-ty-a0-gf-a0.pvnm /lib/firmware/old.bak
Shutdown template.
My default kernel for sys-net was : 5.15.52 (or 5.15.84, unsure ).
So i went to
and Downloaded the following in a VM
- kernel-5.10.112-1.fc32.qubes.x86_64.rpm
- kernel-devel-5.112.104-1.fc32.qubes.x86_64.rpm
- Kernel-qubes-vm-5.112.104-1.fc32.qubes.x86_64.rpm
I went to dom0 :
qvm-run -p personnel ‘cat home/downloads/kernel-5.110.112-1.fc32.qubes.x86_64.rpm’ > kernel-5.10.112-1.fc32.qubes.x86_64.rpm
Do the same for the 3 downloaded files.
Install them one by one with :
sudo dnf install kernel-XXXX.rpm
Go to sys-net settings, change to the new kernel (Sys-net settings → Advanced → Kernel 5.10.112).
Reboot and get wifi ![]()
PS : I tried with kernel 5.10.104 for sys-net, the wifi was working but there were a problem with a current pop up that was appearing in my top right screen saying : device available and device unavailable. Changing to kernel 5.10.112 fixed it ![]()
I did NOT try all the kernel between the one I had by default and the 5.10.101. I tried updating to latest kernel but wifi did not work
I also add a small issue with my USB keyboard :
Open /etc/qubes-rpc/policy/qubes.InputKeyboard & Add at the top of the file: sys-usb dom0 allow
