Using a M2 PCIe adapter which the installer detects just fine yet the vendor firmware does not recognize it as boot medium / at all
Booting from SATA SSD (1st slot), M2 as secondary storage pool works fine
Monitors attached to either of the AMD cards don’t get recognized. But the cards themselves show up correctly in qvm-pci and lspci. So no video output. EXCEPT once the Qubes shutdown progress bar screen kicked in on the monitor attached to the RX550’s DVI port.
mainly because of the desire to boot from M2 but also for security reasons I wanted to get LinuxBoot on this thing.
I learned the hard way that the linuxboot repo is rather a collection/ showcase of PoCs to convey the concept and not really something one simply builds in an evening.
Followed along Trammel Hudson’s post and got the stock rom extracted but when trying to build this the headaches started.
From your post in Heads Testing I can see that the board was still there less than 2 years ago although UNTESTED. But that’s way better and more recent than anything I dealt with to this point.
The story is known to me only very vaguely that linuxboot and heads emerged from NERF and I never got my feet wet with either of them.
Tomorrow I’ll look into how to build heads and when the board fell out precisely but maybe you’ve got some general advice for me? Anything to be wary of?
Any thoughts or recommendations would be much appreciated really.
You should ask those questions under linuxboot community. Unfortunately, there was one board tested under Heads and it was qemu-linuxboot, which after NERF splitting into linuxboot and Heads, server machines under UEFI (not coreboot) went not only untested, but unmaintained.
I would not even know where to start to bring that board back under Heads and stitch an UEFI based Rom WITH Heads today. The knowledge was lost, until it is brought back.
That would be a nice experiment to try. Do a search for linuxboot book, try to join Slack channel and keep us posted?
I’m having the impression that there really is no dedicated LinuxBoot community. There are people using the concept but no real dedicated community. There’s the OSF slack of course but about firmware in general.
A while back I talked to OrangeCMS about the R630… He actually did what you lined out at 38C3 on a Lenovo X270, basically ripping out unneeded parts of the UEFI stock firmware (network driver stuff mostly) and gaining enough space to embed LinuxBoot. Lots of trial and error as he said.
I’m having other OS-related issues with the GPUs that do not make sense to me so this machine is just used for fiddling with the sys-gpu thingy and trying to remotely access it. That’s why I’m less excited about experimenting on this.
I’d need some 3mdeb’s RTE or fiddle myself some rpi zero into doing that. Trial and error is fine, manual powercyclling and debug log investigation is not.
Hopefully I’ll get back to this thread soon while making progress but idk I feel like nobody owns this board and I get opinions from people but nobody can verify/ testify.
There’s an integrated card with VGA (Matrox Electronics Systems Ltd. G200eR2).
I used that for installation, basic setup and usage.
The RX550 (HDMI + DVI, low profile) and the W4100 (4x miniDP, low profile) are both PCIe cards that I attached additionally.
Goal was to get the the W4100 attached to monitors to have a pleasant desktop experience and having the RX550 attachable for any VM that needs it.
However I get zero reactions of those both cards (although showing up) except when shutting down and seeing the Qubes shutdown loading screen as described.
I blacklisted the W4100 and at least then it did not do the “Q” shutdown logo thingy.
If you’ve got any ideas or any direction to point me at I’d be more than grateful! =)
PS: I did not yet try the full sys-gpu-gui thingy on it, that might be another goto, but from desktops I’m expecting this to either work or not. Not what I experienced, it’s strange.
