Dell G15 5530
Remarks
Changed from RAID to AHCI in SETUP. RAID was making everything take literal hours, formatting process was taking literal days. Lots of timeouts in IO on the disks, systemd-udev-settle.service was not loading at all.
LVM was not working. When attempting automatic partitioning or trying LVM on the custom partitioning, I would get the message "resource to create this format lvmpv is unavailable. I used BTRFS which I am more familiar with anyway.
Secure boot enabled.
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Dell Inc.
model: |
  Dell G15 5530
bios: |
  1.20.0
cpu: |
  13th Gen Intel(R) Core(TM) i5-13450HX
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:a719] (rev 01)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Raptor Lake-S UHD Graphics [8086:a78b] (rev 04) (prog-if 00 [VGA controller])
  NVIDIA Corporation GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU] [10de:25ec] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Device [8086:7a70] (rev 11)
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
memory: |
  32452
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.3
    xen: |
      4.17.4
    kernel: |
      6.6.48-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Update: I reinstalled Qubes and LVM was working properly (the default automatic partitioning).
I was wrong about secure boot, it was turned off and it only works without it.
Changing display to non hybrid mode on SETUP rendered the screen black after booting. I’ll keep trying to figure out how to properly configure both the intel and the nvidia cards.
Dell UEFI/BIOS SETUP are always weird in my experience. I loaded default settings for SETUP because I was having trouble booting, and I really don’t know what changed because I checked everything and I had the same config as before. I think they try hard to ensure there will be opaque recovery options and intrusive ways for remote support or something.
thanks Sven
