What the default memory balancing setting in global config? I was scrolling through and accidentally changed them. Want to make sure it’s at the default
Check out the qmemman.conf file. Path: /etc/qubes/qmemman.conf in dom0. It shows the current value and the default values in the comment
Example: cat /etc/qubes/qmemman.conf
