When exactly will be released
template debian-13
template fedora-42
How can I download and install it?
template debian-13
template fedora-42
Trixie - Not yet.
Fedora-42 is already in testing for 4.3, but not 4.2
They will be released when they are ready.
You will be able to download first stabs from the template-testing repository.
Final releases using qvm-template from the standard templates
repository.
Announcements will be made when they are ready for release.
Hi @Unman, is there a repo you can point us at where work on 4.2 version of F42 is being done? My initial search didn’t yield much…
I believe they implied F42 was not being tested for 4.2, but instead 4.3 only.
You can refer to this post to find the latest testing .iso for Qubes 4.3.
As I understand there’s no prospective date for 4.3’s release.
One of the last major blockers for Fedora 42 release is currently being worked on:
If I read that correct, does that imply you’re trying to update the gui from F37 to F42? That’s exciting. I thought I’d read elsewhere that it was only going to be F41.
Sorry for misunderstanding. To clarify, for Qubes OS r4.3, dom0 will be updated from F37 to F41 (not Fedora 42).
But for both Qubes OS r4.2 and Qubes OS r4.3, it is possible to setup one or more inidividual GUIVMs separate from dom0. The documentation on how to setup a GUIVM is available here:
At this moment, the GUI Domains are based on Fedora 41 template. But making them compatible with Fedora 42 template is in the plan.
Since I am not so good at programming Mullvad VPN I immediately thought of the next new
template Debian-13
or
Template Fedora-42
to use.
Not that I have to repeat it in a few days.
According to the internet test: Connection check | Mullvad VPN
The connection check is in the green area.
However, the system tells me “Install new templates with Template Manager”.
Now my question, what should I do now, what and how should I renew what or how is that meant what I should do exactly?
Could you clarify what you are trying to accomplish? I dont see the connection between Mullvad’s VPN Connection check & Qubes’ “Install new templates with Template Manager”?
