so I suppose for now there is no upgrade path for debian 10 to 11 in 4.1?
I tried the https://www.qubes-os.org/doc/template/debian/upgrade/
but its failing with it can’t find the repo or something ?
could you cat the sources.list and sources.list.d/qubes-r4.list?
Those are the sources that debian pulls packets from. If you have a typo in there you won’t be able to pull packages. You could also check if networking generally has any problems…
well thanks but all I did was follow the docs, cut and paste the command and change out buster for bullseye
so, I’m guessing this isn’t yet supported for bullseye and is for earlier upgrades?
Can you be more specific? What exactly does it say?
Note also there is a specific instruction for debian 10 → 11 migration at the end of that doc.
ok sorry, didn’t realize / read … seems it needed the security sources
