Customize Firefox in TemplateVM
I saw there is a topic for customizing it inside a disposable VM.
What I want to do is customize it in a template VM and then everywhere I’ll use FF based on that template to have those customizations [plugins and changes inside about:config]
How can I do so?
Tried qvm-run custom-template firefox-esr and then created a new qube based on that template but didn’t help
When you create a new AppVM, its /home directory is not taken from the TemplateVM.
You could customize an AppVM and then clone it. Would it solve your issue?
That solved my problem configuring FF for all qubes that will use it.
Thank you
What about for a dispvm?
Have a look here: Disposable customization | Qubes OS
