Does anyone use custom menus on the new Qubes OS (4.2.1)?
I used to use custom menus for each VM that I was using. I managed to find how a menu is created in XFCE so I can add it in the toolbar and open shortcuts of the apps directly from the custom menus.
For some reason, that way is not working anymore now.
I will explain the way below:
- create a new item: right click on the toolbar > Panel > Add New Items… > Applications Menu or Launcher (Qubes 4.1.2 was Launcher, now I see it is Applications Menu)
- next was to right click on the new icon > Properties, on the new window I was choosing a specific .menu file that I create.
Before creating .menu file:
- first was to create a folder (/home/[dom0_user]/Menu) with other subfolders for each VM
- each subfolder has its own .menu file and another subfolder called “applications” where all the .desktop files for that specific VM are.
- to copy the .desktop files for the applications which you want to put on the .menu go to “/home/[dom0_user]/.local/share/applications” and copy the desired .desktop files to “/home/[dom0_user]/Menu/[VM_name]/applications”.
- add the .desktop file(s) path/file to the .menu at and
Creating .menu:
<!DOCTYPE Menu PUBLIC "-//freedesktop//DTD Menu 1.0//EN"
"http://www.freedesktop.org/standards/menu-spec/1.0/menu.dtd">
<Menu>
<Name>[VM_name]</Name>
<!-- Read standard .directory and .desktop file locations -->
<DefaultDirectoryDirs/>
<DefaultMergeDirs/>
<!-- Add stock tarball installs to menus -->
<AppDir>/home/[dom0_name]/Menu/[VM_name]/applications</AppDir>
<Include>
<Filename>org.qubes-os.vm.[VM_name].firefox-esr.desktop</Filename>
<Filename>org.qubes-os.vm.[VM_name].org.gnome.Terminal.desktop</Filename>
<Filename>org.qubes-os.qubes-vm-settings.[VM_name].desktop</Filename>
</Include>
<Layout>
<Separator/>
<Separator/>
</Layout>
</Menu>
Just to be sure that I am not doing something wrong and to avoid any supposedly XFCE changes that were done in the mean time… I picked a .menu file located in “.config/menus/applications-merged/” … same thing. a small empty box is shown when I click the custom menu.
It seems to be an issue with the layout/the way the items are sown.
The difference that I can see is that on the .menu files located in “.config/menus/applications-merged/” here is no section.
Does anyone know what else I can try?
Thank you.
