Hi all,
I installed some HVMs and standalones and I have a missing icon(qube) in my task manager for them. Any chance I can change those for something else?
Would you please clarify a little bit. When you mention Custom icons, does that mean you have created custom labels and/or icons? A screenshot is also going to be helpful (if you are willing to share them). And by the task manager, do you mean Qube Manager or the Qui Domains systray widget?
Sorry for that.
I didn’t do anything yet as I’m a bit new to the system and not sure where I should place the icons. I’m using Plasma and it’s task manager widget, but XFCE has some sort of equivalent of that.
This is your screenshot and the icons I’m talking about are the top-left ones:
The missing icons belong to Xterm? Or any specific program? If yes, could you specify the name of those programs?
Sorry again for that, it’s actually happens only for the Windows 11 and I’m guessing it’s due to inability to use the seamless mode. All other HVMs and Standalones are working fine, I just messed some things with them.
I’m using Qubes 4.2.4 (R4.2) without QWT.
Any workaround you can suggest please?
I am not using Windows 11 (or QWT) at this moment, but I believe Icon update from Windows HVM indeed requires QWT installed on that HVM. There are threads in the forum on how to extract QWT from the latest r4.3 repositories and how to install them on Windows 11 HVM on r4.3. I suggest you study those threads.
Alright I will, thanks
