Crontab not working when passwordless root is disabled --- any ideas?
I have enabled the dom0 user prompt for root according to this guide: Passwordless root access in qubes | Qubes OS
The consequence of this is that the cronjob no longer works. It gives a pam issue even for cronjobs that are just user crons without any root because the cron daemon itself cannot start or something weird. Does anyone have any idea on how to get cron working while having the dom prompt?
The error in systemctl status is the following. Any ideas?
Jan 01 19:20:01 testing crond[72614]: (user) PAM ERROR (Failure setting user credentials)
Jan 01 19:20:01 testing crond[72614]: (user) FAILED to authorize user with PAM (Failure setting user credentials)
Jan 01 19:21:01 testing crond[72654]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Jan 01 19:21:01 testing crond[72654]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Jan 01 19:21:01 testing crond[72654]: (user) PAM ERROR (Failure setting user credentials)
Haven’t tried troubleshooting cron yet. Try replacing cron with systemd-cron?
Yeah, systemd-cron works in Qubes 4.1 templates - crontab, /etc/cron.* anacron dirs, etc.
… btw, you may not want to install systemd-cron in the templates - or else all the dependent AppVMs will run all the cruft in /etc/cron.daily, cron.hourly, etc. Instead suggest to install it only in AppVMs where you need it.
Alternately you can install it in templates, disable all its systemd services and timers there (there’s a few) - and reenable them in AppVMs as needed.
