Create Starter Shortcut to Document located in a App Qube
I have a file where I’m saving Linux Commands which I need often but don’t remember…
Now I want to create a shortcut to launch this file directly… Tried to launch Mousepad with the path as parameter but I think Mousepad won’t accept parameters…
Or would you place this text document in dom0 and run it from there?
in dom0. Did you try, in a terminal, qvm-run -a <your_AppVm> 'mousepad <your file>' to open it?
This is nice, simple and works, thank you :slight_smile:
