Well that’s the funny thing : it’s ok they are showing in dom0, but the VGA part was showing (an is stil lshowing) with nouveau driver when I actually blacklisted it
I removed the pci-hide from Grub, but still, nouveau is supposed to be blacklisted and… it seems it still somehow ‘captured’ by the Nvidia card before it is actually blacklisted… Although, a grep nouveau with the dmesg doesn’t show anything…
And the BIOS of my laptop contains so few information, even the ctrl+s doesn’t show much more and noting on about the graphic cards…
Not sure how it plays between the Bios, Qubes and the Hardware… My luck is it works, but I understand it could be very frustrating since there doesn’t seem to be a ‘root cause’/ reason for this to work… Or not…
Welp, adding <feature name='hypervisor' policy='disable'/> under cpu
and changing smbios to “host” and adding <kvm> <hidden state='on'> </kvm> after smbios in addition to what I did above was enough to get marvel rivals working, time to get banned.
Disclaimer: I am not cheating, I dont really care if you cheat but when you get caught cheating you give lazy anti cheat developers a datapoint to sell to lazy game developers that ultimately make things like gaming on linux or a vm much harder
When I Do nvidia-smi I see my RTX 3080
But I just want a different dedicated display to get the benefits of gpu acceleration
what am I supposed to put in
binary=${1:?binary required}
Just need my GPU to display on another screen instead of HDMI where intergrated graphics are, rather use DP so I could get the benefits of of 165 hertz. Currently I’m using intergrated intel graphics to display my main dom0 display.
I got stuck on the AOC.conf file how do I find the variables to plug in and also the next part xorg1sh script have no clue what I put for the binary
So far Ive been able to successfully pass my gpu through to my debian 12 machine but now I just want that debian machine to be on a different display so I could actually see the benefits of GPU passthrough on a visual level outside of of LLMs
I recently revisited this, when I’m not gaming I use my passthrough monitor for multi-tasking. Previously I had a qubes-template based ubuntu install, but after using for a few months I noticed it had a lot of… problems.
TLDR:I run a script that copies the updated AOC.conf to /etc/x11/xorg.conf every boot so I can use lightdm without any problems
If you are like me and too dumb to figure out the intricacies of using template based hvms or the bash scripts OP listed, you can just install an hvm with any plain old iso, give it normal pci passthrough, and then:
Disable autostart of display manager, I.E sudo systemctl disable lightdm
Copy in AOC.conf and change to nvidia or whatever if you need (literally just change the words amd to nvidia)
Download nvidia-firmware or whatever drivers you need
Change startx11.sh to something like:
#!/bin/bash
# binary=${1:?binary required}
# Find the correct BusID of the AMD GPU, then set it in the Xorg configuration file
pci=$(lspci | grep "VGA" | grep -E "NVIDIA|AMD/ATI" | cut -d " " -f 1 | cut -d ":" -f 2 | cut -d "." -f 1 | cut -d "0" -f 2)
sed -i 's/"PCI:[^"]*"/"PCI:0:'$pci':0"/g' /home/user/AOC.conf
# Start the Xorg server for the X screen number 1.
# The X screen n°0 is already used for QubesOS integration
# sudo startx "$binary" -- :1 -config /home/user/AOC.conf
sudo cp /home/user/AOC.conf /etc/X11/xorg.conf
Finally, start your display manager or whatever normally or not normally i.e.: sudo systemctl start lightdm
For a more integrated solution someone can make the changed bash script above into an init service that whichever display manager or script “requires” so it runs first.
You should be able to run vanilla debian or whatever without any other changes, although I don’t know about sound.
You don’t need to change binary=${1:?binary required} in the script, ${1} is a value of first argument that is passed to the script. if first argument is not provided then “binary required” string will be used in startx and I guess you’ll see this string in the startix error message.
You need to pass the argument to the xorgX1.sh script e.g.:
sudo ./xorgX1.sh ./i3.sh
Then binary=${1:?binary required} will be binary="./i3.sh".
Okay so Rebooted the debian VM and heres what I get when I do
Result of execution
non-network local connections being added to access control list
/bin/sh: 1: dex: not found
** (xss-lock:2073): WARNING **: 06:19:23.150: Error getting session: GDBus.Error:org.freedesktop.login1.NoSessionForPID: PID 2073 does not belong to any known session
[libi3] ../libi3/font.c Using Pango font monospace, size 8
i3status: trying to auto-detect output_format setting
i3status: auto-detection: parent process is "sh", looking at its parent
i3status: auto-detected "i3bar"
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 00e00002
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 00e0000e
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 00e00015
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 00e0001c
[../i3bar/src/xcb.c:1055] ERROR: PropertyNotify received for unknown window 00e00023
xss-lock: ./src/xss-lock.c:469: logind_session_set_locked_hint: Assertion `logind_session' failed.
Aborted
i3lock: Cannot grab pointer/keyboard
The unknown window Error pops up when I switch to my DP display on monitor from my HDMI display.
Every time I switch to Display port I get a black screen
Why would this be happening?
I have 0 issues running cyberpunk 2077. (using a linux guest).
If you are using a windows guest, be sure to only enable the screen for you gpu passthrough. If both are activated, you should have terrible performances.
