I’m currently can’t retrieve the IOMMU groups at all for some reason. I’m booting a live distribution with iommu=1 and iommu_amd=on params, I check afterwards that these params are loaded, but when I check for ls /sys/kernel/iommu_groups it shows nothing. I checked the dmesg and it says operation not permitted. I definitely remember it worked last time when I checked this, not much have changed I think.
Any ideas what I missed or forgot?
I did the ... to remove potential fingerprinting info.
I’m almost certain it shouldn’t be an issue, as the last letters (rev a1) appears only once in the whole list of devices and the (rev 05) appears multiple times.
But please, can someone just clarify this for me, so I won’t spend enormous time just to find out it’s impossible for me to passthrough this GPU?
So I have been spending this entire time trying and trying to get the GPU to work with support from AMD on the whole driver issue and still just a big mess. Not working.
Ive recently experienced today error when starting a qube with the connected gpu and get unkown PCI header type 127.
Now my device has not shutdown until after this error when attempting multiple reboots(6 to be percise) still persisting with this error.
When I got my issues with the Windows standalone sorted 2 days ago I tried with the GPU connected and didnt detect the device either.
Yes I have done this guide to the full extent and beyond.
This is a recent issue. Have not had this happen prior however then with prior tests for attaching the gpu there were just driver issues that is still not resolved and even with trying official support from AMD for last two months results still to no success.
The extent I get is I able able to get a display via a additional montior per the point of the post but not beyond that, even with VirtualGL it will only render with the virtual cpus.
This error is recent. I am aware if the system shutdowns there can be errors which may require multiple restarts to eventually avoid error based on what I read from others experience hence why I would only suspend. However such issue remains as a new matter.
So originally I passed through 03:00.0 and 03.00.1 and add PCI deivces but still couldnt could drivers to work, was as if the gpu wasnt even associated when using VirtualGL:
So attempted now removing 03.00.1 from the qube and now get error:
Unable to reset PCI device 0000:03:00.0: internal error: Active 0000:03:00.1 devices on bus with 0000:03:00.0, not doing bus reset, see /var/log/libvirt/libxl/libxl-driver.log for details
Would I need to revert the passthrough of 03.00.1 as it is in a separate group to fix this error to get the GPU to work?
Thank you for this tutorial. Someone on reddit told me that I could use the integrated graphics of my CPU to use Qubes and my dedicated GPU for my gaming HVM, I found that odd since you set it in the BIOS and now I just don’t have any output if I try switching my screen to the GPU output. Am I doing something wrong or was I right in the first place and definitely need two distinct GPUs as I thought in the first place?
Got it working in less than an hour by scrupulously following the instructions on a RTX secondary gpu.
What I like to do for steam games is run steam on the primary display, and configure game run options as “DISPLAY=:1 %command%” to have them run on the GPU/other display.
I also tested with success x11vnc/xvncviewer to get the game window back on primary display when I need to.
Is there a way to create one common cube both for the HVM mode with a GPU proceeding, and for the possibility of working in PVH mode? After installing NVIDIA-AKMOD, it seems that changes in qube become too significant so that it can work in PvH mode with GUI (even in Pvgrub2-PVH) (the system itself is launched, may enter the terminal. But the X, in principle, will not start and pour mistakes). I tried to make a list of all new installed modules of the /usr and temporarily remove them, but this did not help restore the performance of the PVH mode.
Why are we running startx as root? I’m guessing you need superuser privileges to open a new display, but it seems that can be done separately from running the graphical interface itself:
#!/bin/bash
binary=${@:?binary required}
xorgConf="/opt/separate-head-xorg.conf"
# Find the correct BusID of the AMD GPU, then set it in the Xorg configuration file
lspci | grep "VGA" | grep -E "NVIDIA" && sed -i 's/^Driver .*/Driver "nvidia"/g' "${xorgConf}"
lspci | grep "VGA" | grep -E "AMD/ATI" && sed -i 's/^Driver .*/Driver "amdgpu"/g' "${xorgConf}"
pci=$(lspci | grep "VGA" | grep -E "NVIDIA|AMD/ATI" | cut -d " " -f 1 | cut -d ":" -f 2 | cut -d "." -f 1 | cut -d "0" -f 2)
sed -i 's/"PCI:[^"]*"/"PCI:0:'$pci':0"/g' "${xorgConf}"
# Start the Xorg server for the X screen number 1.
# The X screen n__0 is already used for QubesOS integration
sudo X :1 -config "${xorgConf}" &
DISPLAY=:1 $binary
And I run that as user:
$ my-graphics startxfce4
Without this modification, I was logged into XFCE as root, which seemed a bit weird.
Noticed that if you got a working display/login manger you can just select a wayland session (cosmic) and it works without configuring a display. (Standalone)
Thanks for this guide, reduced the pain to completion significantly for me!
However, there where some quirks I’d like to document here as they may be useful to others.
I used the standard Fedora 41 template as a starting point. The first problem was that I had to start my standalone Qube in PVH mode the first time for the memory and disk size settings to take effect. Then switched to HVM mode and passed the GPU.
I opted to install i3 directly from upstream and not from the Qubes OS repo, since that version has patches for running in dom0:
sudo dnf install --repo=fedora i3
To avoid conflicts when updating, I furthermore excluded i3 from the Qubes OS repo by adding exclude=i3 to /etc/yum.repos.d/qubes-r4.repo.
Fedora, of course, comes with SELinux which did not like the switch from sudo to user to sudo which happens with the scripts provided above (xorgX1.sh is invoked as super user, i3 is started as user but in the same line we run xhost as super user). That’s easily fixed by running xhost on a separate line. I furthermore had problems with D-Bus not working. Setting the bus address environment variable solved that for me so I didn’t look into it further.
Here are my scripts:
#!/bin/bash
binary=${1:?binary required}
config="/home/user/xorg.conf"
lspci | grep "VGA" | grep -E "NVIDIA" && sed -i 's/^Driver .*/Driver "nvidia"/g' "$config"
lspci | grep "VGA" | grep -E "AMD/ATI" && sed -i 's/^Driver .*/Driver "amdgpu"/g' "$config"
sed -i 's/"PCI:[^"]*"/"PCI:0:'$pci':0"/g' "$config"
sudo startx "$binary" -- :1 -nolisten tcp -config "$config"
