I am trying to copy the file “qvm-fedora-upgrade” dowloaded from
from qube “Work” to my home directory in dom0 with the command:
qvm-run --pass-io Work 'cat /home/user/Downloads/qvm-fedora-upgrade' /home/gz/qvm-fedora-upgrade
This results in:
File "/usr/bin/qubes-vmexec", line 5, in <module>
sys.exit(main())
File "/usr/lib/python3.14/site-packages/qubesagent/vmexec.py", line 55, in main
os.execvp(command[0], command)
File "<frozen os>", line 604, in execvp
File "<frozen os>", line 627, in _execvpe
FileNotFoundError: [Errno 2] No such file or directory```
Suggestions very welcome.
If that is verbatim then you have not included a redirect: qvm-run --pass-io Work 'cat /home/user/Downloads/qvm-fedora-upgrade' > /home/gz/qvm-fedora-upgrade
Executing: qvm-run --pass-io Work 'cat /home/user/Downloads/qvm-fedora-upgrade' /home/gz/qvm-fedora-upgrade
results in:
sys.exit(main())
