Hello, is it possible to Copy from Terminal to another VM?
Since in a terminal you cant copy anything just with CTRL+C one step in the copay and paste move is missing.
Thanks
Thanks
You do not say what terminal you are using. Most “advanced” provide a
Menu item under “Edit” to use, or you can configure to automatically copy
selection to clipboard.
In Xterm and the like you can configure to copy selections to clipboard.
Its the xterm Terminal.
“In Xterm and the like you can configure to copy selections to clipboard.”
Would you mind to tell me how?
I dont see any wy on how to configure anything. I have the qube, in it i have xterm. Thats it.
Nice.
Please dont project your own obsession with CP on to other users.
Or are you referring to pasting into Terminal?
and you might need a text editor in the second Qube, receiving the Text.
In the Qube, in the list of Options.
Settings
Several Tabs over is a list of possible applications one can install.
Well, there are two cases:
Yeah - asking for help and using language like that - it’s a whole new approach.
To copy from terminal, after selection I used to right click with the mouse and then select copy
Yeah wtf is wrong with that guy?
