Hey guys, I have a similar issue.
My setup looks like this:
Tor → VPN1 → VPN2 → Clearnet
I am well aware of dangers of using VPN this way, I’ve been reading the documentation for two weeks non stop. This is a specific need, and VPN2 is disposable, while VPN1 is also disposable, just lives a little bit longer. They are just for few VMs, while the majority of my work happens using just sys-whonix.
Now my issue.
I have Qubes v4.2 and I have set it up using iptables and CLI scripts with the adjustments etaz provided, the later ones in the comment too.
In my sys-whonix I have disabled the transparent gateway and I am strictly using stream isolation.
For VPN1, in ovpn file I have set socks-proxy to my sys-whonix and its working fine, while VPN2 does not have it.
For both of them resolv.conf has the virtual DNS. 10.139.x.x
When I am echoing the DNS servers qubes-vpn-handler sets the vpn_dns to - it shows something like 192.168.x.x . My understanding is that it is pulling VPN nameservers.
The conenctivity is fine, just the DNS is broken similar to previous comments. I have to manually change resolv.conf in VPN2 to some public DNS server (lets say 8.8.8.8), and do the same on the VM that connects to it to get things working. (the machine is win10 standalone VM).
I understand that thanks to sys-whonix I am still protected, but every time I do that I have a very uncomfortable feeling.
I need help to properly set this up so I can be sure it works as expected.
My understanding was that I could chain these qubes without issues, but it does not seem to be the case.
Here’s my files. Can anyone help me please get this right and understand the solution? I suspect something needs to be adjusted in firewall rules, but I am not very well versed here to make changes.
qubes-firewall-user-script:
#!/bin/bash
# Block forwarding of connections through upstream network device
# (in case the vpn tunnel breaks):
# Prevent the qube to forward traffic outside of the VPN
nft insert rule qubes custom-forward oifname eth0 counter drop
nft insert rule ip6 qubes custom-forward oifname eth0 counter drop
nft insert rule qubes custom-forward iifname eth0 counter drop
nft insert rule ip6 qubes custom-forward iifname eth0 counter drop
# Block output hook
#nft 'add chain qubes output { type filter hook output priority 0; policy drop; }'
# Accept traffic to VPN
nft 'add chain qubes output { type filter hook output priority 0; policy accept; }'
#iptables -P OUTPUT ACCEPT
#iptables -F OUTPUT
# Add the `qvpn` group to system, if it doesn't already exist
if ! grep -q "^qvpn:" /etc/group ; then
groupadd -rf qvpn
sync
fi
sleep 2s
# Block non-VPN traffic to clearnet
nft insert rule ip qubes output oifname eth0 counter drop
#iptables -I OUTPUT -o eth0 -j DROP
# Allow traffic from the `qvpn` group to the uplink interface (eth0);
# Our VPN client will run with group `qvpn`.
nft insert rule ip qubes output oifname eth0 skgid qvpn accept
#iptables -I OUTPUT -p all -o eth0 -m owner --gid-owner qvpn -j ACCEPT
qubes-vpn-handler.sh
#!/bin/bash
set -e
export PATH="$PATH:/usr/sbin:/sbin"
case "$1" in
up)
# To override DHCP DNS, assign DNS addresses to 'vpn_dns' env variable before calling this script;
# Format is 'X.X.X.X Y.Y.Y.Y [...]'
if [[ -z "$vpn_dns" ]] ; then
# Parses DHCP foreign_option_* vars to automatically set DNS address translation:
for optionname in ${!foreign_option_*} ; do
option="${!optionname}"
unset fops; fops=($option)
if [ ${fops[1]} == "DNS" ] ; then vpn_dns="$vpn_dns ${fops[2]}" ; fi
done
fi
nft flush chain ip qubes dnat-dns
#nft add chain qubes nat { type nat hook prerouting priority dstnat\; }
#iptables -t nat -F PR-QBS
if [[ -n "$vpn_dns" ]] ; then
# Set DNS address translation in firewall:
for addr in $vpn_dns; do
nft add rule qubes dnat-dns iifname == "vif*" tcp dport 53 dnat "$addr"
nft add rule qubes dnat-dns iifname == "vif*" udp dport 53 dnat "$addr"
#iptables -t nat -A PR-QBS -i vif+ -p udp --dport 53 -j DNAT --to $addr
#iptables -t nat -A PR-QBS -i vif+ -p tcp --dport 53 -j DNAT --to $addr
done
# su - -c 'notify-send "$(hostname): LINK IS UP." --icon=network-idle' user
fi
down)
#su - -c 'notify-send "$(hostname): LINK IS DOWN !" --icon=dialog-error' user
# Restart the VPN automatically
#sleep 5s
#sudo /rw/config/rc.local
esac
