After updating the kernel in dom0 to 6.1.35, laptop has been rapidly heating to 70 degrees (before the update would stay at 45) within 5 minutes even when no qubes other than dom0 are running (used qubes.skip_autostart when booting).
No processes are using any more cpu/memory than before using both top and xentop.
Version 5.15.103 doesn’t have this issue, so installed some of the kernels from https://yum.qubes-os.org/r4.1/current-testing/dom0/fc32/rpm/ and found that the issue starts between 5.15.103 and 5.15.111
I’m trying to compile and do a git bisect to find what caused it. I tried using Qubes builder to get the kernel source in a fedora-32 qube, but it failed with this message after running make get-sources:
--> Downloading additional sources for linux-firmware...
make[1]: Entering directory '/home/user/qubes-builder/qubes-src/linux-firmware'
make[1]: Leaving directory '/home/user/qubes-builder/qubes-src/linux-firmware'
--> Verifying the sources...
--> Downloading additional sources for linux-kernel...
make[1]: Entering directory '/home/user/qubes-builder/qubes-src/linux-kernel'
if [ -f /usr/bin/qvm-run-vm ]; \
then qvm-run-vm --no-gui --dispvm 2>/dev/null zcat <macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.gz.UNTRUSTED > macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.UNTRUSTED; \
else zcat <macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.gz.UNTRUSTED > macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.UNTRUSTED; fi
/bin/sh: -c: line 0: syntax error near unexpected token `('
/bin/sh: -c: line 0: `sha256sum --status --strict -c <(printf "1641a09e8ae4fc494b8e44f1bc86d19cefcdc5ad74722ce058148b35a194aeb6 -\n") <macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.UNTRUSTED || \'
make[1]: *** [Makefile:100: macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar] Error 1
rm macbook12-spi-driver-2905d318d1a3ee1a227052490bf20eddef2592f9.tar.UNTRUSTED
make[1]: Leaving directory '/home/user/qubes-builder/qubes-src/linux-kernel'
make: *** [Makefile:226: linux-kernel.get-sources-extra] Error 2
How do I fix this issue? If it’s relevant, no dispvm were started at this part of the process.
What’s the proper way to build the kernel for a bisect? Should I be using Qubes builder to get Qubes-specific patches, or can I use the source from git.kernel.org directly?
