Command to install specific kernel - edge case
I need to Install kernel 6.0.7 in Dom0 (Qubes 4.1)
The package exists
https://ftp.qubes-os.org/repo/yum/r4.1/current-testing/dom0/fc32/rpm/kernel-latest-6.0.7-1.fc32.qubes.x86_64.rpm
but won’t install when I run
sudo qubes-dom-update --releasever=4.1 --enablerepo=qubes-dom0-currrent-testing kernel-latest-6.0.7
“unable to find a match”
I pulled it manually, moved to dom0 and ran dnf install, but would like to do it the proper way.
Also is there a one-liner to then set this kernel as the default (without needing to edit a text file by hand as I need to automate)
Also would be good to know the qubes-dom0-update equivalent of Debian’s apt pinning so the dom0 kernel doesn’t ever get updated (to a version which breaks suspend, as the latest does)
