Hi!
I need to start ibus-daemon when app vm starts up.
So I added to rc.local file
#start ibus
ibus-daemon -drx
# test if rc.local is executed
echo test > /home/user/log
And I see log file says test but ibus-damon is not running.
What am I doing wrong here?
adw
2
Did you make rc.local executable?
chmod +x rc.local
Yes it is
rwxr-xr-x 1 root root 409 Feb 18 09:29 rc.local
ludovic
4
Something should be wrong with the ibus start command.
- check the environment before the launch, ex:
set > /tmp/set.log
- is the
ibus-daemon in $PATH? → Use the absolute path
- add logs, ex:
ibus-daemon -drx > /tmp/ibus.log 2>&1
- check the command options, maybe add verbose output
- read the
ibus-daemon documentation
