This did the trick (on r4.3). I expected it to be applied system-wide via export TERMINAL="something".
Hopefully would be back-ported to r4.2 after some testing.
I’m indeed on 4.2
… which is normal, because 4.3 has not been released yet! ![]()
As barto have already noted, one of the easiest ways to manage this is using update-alternatives to determine x-terminal-emulator (since it has the highest hard-coded priority) by either declaring it with
update-alternatives --install /usr/bin/x-terminal-emulator x-terminal-emulator <path_to_your_terminal> <priority>
or configuring from existing choices:
update-alternatives --config x-terminal-emulator
There are 4 choices for the alternative x-terminal-emulator (providing /usr/bin/x-terminal-emulator).
Selection Path Priority Status
*0 /usr/bin/xterm 40 auto mode
1 /usr/bin/koi8rxterm 20 manual mode
2 /usr/bin/lxterm 30 manual mode
3 /usr/bin/uxterm 20 manual mode
4 /usr/bin/xterm 20 manual mode
Press <enter> to keep the current choice[*], or type selection number:
With bigger number being higher priority
Exactly my point too ![]()
I could have been testing 4.3 ![]()
Ah cool, I did not know it could handle terminal emulator
I need to check of you script this to not use interactively.
On fedora 41 update-alternatives --config x-terminal-emulator does nothing.
Installing a link worked though.
update-alternatives --install /usr/bin/x-terminal-emulator x-terminal-emulator /usr/bin/gnome-terminal 5
