Has anybody in Qubes community ran Chipsec on their system to see the results? Runs from UEFI/BIOS
shell
Can also be run from linux and other OSes inside a VM
Try and tell. ![]()
I feel like creating a bootable live OS would be a good way to make firmware analysis easier
I’ll be running chipsec over the weekend. Will find out if qubes allows access to bios through the VM.
I’ll also test it with kicksecure templates since that should prevent some of chipsec to not work
When you are done if you could post the steps you followed an the results if possible.
