So I was able to get into my qubes even though I forgot to enable keyboard once I did my sys-usb.
Think PS/2.
I am typing the command in dom0 so that USB keyboard will work which is this…
sudo qubesctl state.sls qvm. sys-keyboard
I hit enter and dom0 gives me this…
[ERROR ] Template was not specified incorrectly : False
local :
Data failed to compile:
No matching sls found for ‘qvm.sys-keyboard’ in env ‘base’
DOM0 configuration failed, not continuing
I use what was stated in the docs I was finging which is this…
sudo qubesctl state.sls qvm.sys-keyboard
And that didn’t work usb keyboard was stilled locked out. So I was using a PS/2 keyboard to log-in to my Qubes and type everything .
Did another dom0 update just too make sure all was good still no usb keyboard…
Upon days of digging and reading I came across a qubes old doc that stated the same command but only a slight change …
sudo qubesctl state.sls qvm.usb-keyboard…
It worked after rebooting and the USB keyboard
has been working since and my (sys-usb) is running awesome!!
