Hello everyone.
Qubes 4.04 doesn’t seem to want to play audio over HDMI. Pulse volume control only sees the digital S/PDIF output.
Any ideas?
Hello everyone.
Any ideas?
Did you go to the Configuration tab and try to find HDMI there? That’s how I do it.
Thanks Deeplow. That worked.
Perfect! You’re welcome!
Edit: made the title a bit from specific about the problem.
Yeah the default view of the pulseaudio volume control sort of hides the configuration options. You have to make the window wider. Thanks again!
