I can’t copy the contents from the sys-net terminal or other minimal qubes’ terminal. I use ctrl-insert and then ctrl-shift however 0 bytes are copied. I can paste the content in the terminal with shift-insert however it seems the qubes global clipboard is not detecting the insert clipboard. Is there a fix for this? It makes it impossible to copy from terminals.
[deleted]
Are you using xterm or gnome-terminal? Or another terminal-emulator?
I’m using xterm as my default terminal here
I don’t think this is Qubes specific, but rather Xterm specific.
Try to add
XTerm*selectToClipboard: true
to the ~/.Xresources
Now run
xrdb -merge ~/.Xresources
and restart xterm.
